vcMoveJointStatement
Move Joint statement uses a servo controller behavior to move a joint to given value and waits until the motion completes.
| Controller | vcBehavior | RW | Gets or sets the controller that owns the joint.See moreThis can be a servo controller or a derived controller, e.g. a robot controller. Must be from the same component. |
| MotionTimeProperty | vcExpressionProperty | R | Gets an expression property for motion time.See moreThis can be left empty to let the controller plan the motion. If not left empty, this expression must evaluate to a Real or Integer result. |
| TargetValueProperty | vcExpressionProperty | R | Gets an expression property for the target value. Must evaluate to a Real or Integer result. |
